reassembly of starter clutch 66 dream 305
Whoops... I must retract my last few posts. We just did a starter clutch and you have to put the sprocket on BEFORE the rotor. As an assembly, the sprocket will not go over the woodruff key which must be in place before the rotor can go on. In summary, Sprocket first, woodruff key, then rotor. A little silicone grease on the rollers will help keep them in place.
As George W.Bush said "I must have misremembered."
-48
-48
rzgkane
Ahh yes. The woodruff key. Forgot about that.
48lesco wrote:Whoops... I must retract my last few posts. We just did a starter clutch and you have to put the sprocket on BEFORE the rotor. As an assembly, the sprocket will not go over the woodruff key which must be in place before the rotor can go on. In summary, Sprocket first, woodruff key, then rotor. A little silicone grease on the rollers will help keep them in place.
-48
