mix and match case halves
Bernhard
Post by Bernhard » Thu Nov 03, 2011 8:36 am
I would suggest you obtain some engineers blue and see if;
1st, the faces match up,
2nd the crankcase bearing faces match with a bearing inserted in each section one at a time.
Any mismatch on the 1st one may give you oil leaks, and the 2nd, well depends on how much distortion/ mismatch you are talking about, or approach it by the gung-ho method and suck-it and see!
Post by LOUD MOUSE » Thu Nov 03, 2011 10:27 am
The cases will match just fine as HONDA made them to be that way.
If ya want to go through a bunch of checking (European engines required ya do it) than go ahead but these 250/305 cases match!. ........lm
Bernhard wrote:I would suggest you obtain some engineers blue and see if;
jerry
Post by jerry » Thu Nov 03, 2011 1:06 pm
I use mismatched cases on some of my race engines with no ill effects or oil leaks. All the best Jerry
rrietman
Post by rrietman » Thu Nov 03, 2011 11:19 pm
Well, I'm going with Ed and Jerry on this.
Randy
BTW Ed It will be early/mid december when I am in your neck of the woods.
Post by LOUD MOUSE » Fri Nov 04, 2011 8:43 am
Do come by.
I have a forum member here now and we are working on his 1964 CB77. ..................lm
rrietman wrote:Well, I'm going with Ed and Jerry on this.
Randy
