Camshaft removal help!
Bryanwingen
Post by Bryanwingen » Mon Nov 09, 2015 5:49 pm
Al,
I think I was confusing on my post, I need to get it out but couldn't get it back in to get the advancer out but now I'll know how to get it back together. Now to get those damn bearings going.
Post by LOUD MOUSE » Mon Nov 09, 2015 5:58 pm
Both cams come out after you have (as you show) loosened/in your case removed the large nut on the right side and loosened the nut/threaded shaft on the left side.
Just knock them out.
Reassembly is similar but you must look at how you align the cams to the sprocket.
Careful. ...........lm
Bryanwingen wrote:You guys were a huge help! I understand it now, do the bearings push out the side wall as well? It helped to tap off the left side with them mating. You guys are great!
Bryanwingen
Post by Bryanwingen » Mon Nov 09, 2015 6:57 pm
The bearings are NOT coming out with tapping.
Post by LOUD MOUSE » Mon Nov 09, 2015 7:06 pm
All parts come out with tapping. ...........lm
Bryanwingen wrote:The bearings are coming out with tapping.
Bryanwingen
Post by Bryanwingen » Mon Nov 09, 2015 7:10 pm
Haha I thought so too, I'm supposed to get the first bearing out correct? And then put the second bearing into the tunnel and tap it out correct?
Bryanwingen
Post by Bryanwingen » Mon Nov 09, 2015 7:11 pm
I meant the bearings ARE NOT coming out with tapping. I was writing fast while cursing the bike. Haha
Post by LOUD MOUSE » Mon Nov 09, 2015 7:24 pm
They will come out if you use a soft metal at the high lobe of the cam.
If the inside one stays in the head place the soft metal at the outside of the bearing and tap it out. ...............lm
Bryanwingen wrote:I meant the bearings ARE NOT coming out with tapping. I was writing fast while cursing the bike. Haha
