Sprocket cam balance weights?
Post by G-Man » Fri Sep 11, 2015 6:42 am
The two cam halves need to be inserted fully in the sprocket and held with the two tapers. The cam sprocket needs to be perfectly in line with the crankshaft sprocket and the two outer bearings must not be outside the joint face that seals the two end castings. If they do you will have oil leaks at those locations.
modelman
Post by modelman » Fri Sep 11, 2015 8:42 am
I found that upon re-assembly, the left & right side cam-covers, (taco L/side, points R/side) have raised lips that centralise the cam bearings/camshaft once fitted.
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Ericvanrijn
Post by Ericvanrijn » Fri Sep 11, 2015 11:59 am
Thank you, I understand it and will take care.
Kind regards
