right side cylinder smoking
mike1969
right side smoking
Post by mike1969 » Sat Oct 25, 2014 2:33 pm
Guess I spoke too soon about the right cyl. smoking. Hadn't run it for a coupe of weeks.
Was going to take it for the first ride today and the right side starting smoking again.
The clutch is sticking again so no ride for me.
On the plus side it starts instantly and it's charging 13.1 volts.
mike in idaho
Post by mike in idaho » Sun Oct 26, 2014 10:06 am
You might try running it a while with a little Seafoam added to the oil.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
mike1969
right side smoking
Post by mike1969 » Sun Oct 26, 2014 11:45 am
Yeah, sounds like it's worth a try. Hate to tear a good running engine apart.
mike1969
right side smoking
Post by mike1969 » Sat Aug 01, 2015 1:14 pm
The opinions given here were that the right side piston rings were clogged. Over the winter I filled the right cylinder with Marvel Mystery Oil. Got it running again last week and the smoking seems to be gone. I
I'm having another problem now. The clutch plates were stuck together so I got them separated. When I first start the bike neutral is easy to find and it shifts smoothly. After riding for just a few minutes the shifting is a little more difficult and finding neutral while running is impossible. When I shut the engine off shifting to neutral is easy.
Any clues?
mike1969
right cylinder smoking
Post by mike1969 » Mon Aug 03, 2015 7:54 am
Don't everyone answer at once.
Post by G-Man » Mon Aug 03, 2015 11:22 am
Mike
That describes pretty much every bike I have ever owned. Clutches seem to drag a little more when hot than cold.
Could be plates warping a little, notches worn in clutch inner or outer, or just a general changing of toleranecs as the engine gets warm.
Have you dismantled the clutch to take a look?
mike1969
cylinder smoking
Post by mike1969 » Mon Aug 03, 2015 1:29 pm
Thanks for the reply Gman. I took the plates out and cleaned them last summer and the clutch worked ok. I didn't see anything unusual other than the material they are made of. They look like they are made of black tar paper. They still have grooves in them, but not real deep. The clutch doesn't slip.
They were stuck again over the winter and still looked the same. I have an old set from another Dream but they are much thicker. Was thinking of trying them.
