Please Help, Advice needed.. are the motors seized?
CB77
Both appear to be CBs as there is no down tube on the frames. CBs had the TOP engine mounting bolts whereas the CL only had BOTTOM mounting bolts. $600 is an excellent buy so you should jump on them before he gets away. Charlie
Re: CB77
The CL does have one top mounting bolt. .............lm
cbxmountainman wrote:Both appear to be CBs as there is no down tube on the frames. CBs had the TOP engine mounting bolts whereas the CL only had BOTTOM mounting bolts. $600 is an excellent buy so you should jump on them before he gets away. Charlie
RIDE IT DON'T HIDE IT!
CL Engine mounts
I stand corrected. Forgot about the top bracket that also holds the coils/condensor. Was refering primarily to the missing front down tube. That's my story and I'm sticking to it.
Re: CL Engine mounts
It does hold the condenser all right. .............lm
cbxmountainman wrote:I stand corrected. Forgot about the top bracket that also holds the coils/condensor. Was refering primarily to the missing front down tube. That's my story and I'm sticking to it.
