Top end noise.
R100
Post by R100 » Mon Mar 09, 2015 1:51 pm
deafanddiabetic wrote:
R100 wrote:Just taking a stab here.
If you can get it up 1/2" all around, you might be able to peer in with a light. In the past I have had trouble with corroded knock/dowel pins that would not come out.
I'll take a peek in there. If one was rusted to hell, any suggestions on how to remove or break it loose? Heat probably?
Penetrating oil, patience, heat. Or you might see something else in there. Those small lights on a flexible wand are useful in cases like this.
If you need to lever against aluminium, or hit it, use wood. It takes the damage rather than the metal.
48lesco
Post by 48lesco » Mon Mar 09, 2015 1:55 pm
I've never tried to split those cases without removing the rotor, starter sprocket, etc. but I would imagine the case would get hung up on the starter sprocket.
deafanddiabetic
Post by deafanddiabetic » Mon Mar 09, 2015 5:57 pm
Thanks for the input, guys. Ed was right about the crank seal being stuck, it just took a little careful prying. All of my guide pins were A-Okay.
I even left the rotor and starter gear in just fine, since all I need to access is the transmission components.
Ed, I didn't catch your email or anything, but here's a link to a photo bucket of those pictures you requested. Feel free to shoot me a Private Message if there's something you'd like to see else wise.
http://s1381.photobucket.com/user/Benji ... k/library/
deafanddiabetic
Post by deafanddiabetic » Tue Mar 10, 2015 4:52 pm
cron
