Torquing CA77 Head Bolts
Post by LOUD MOUSE » Mon Jul 07, 2008 11:47 am
The sealing washer you need is part number 90441-259-000. .............lm
These washers are only one of the parts items that HONDA messed up with the parts books and fiche. I have the CL72/77 parts books and fiche and they show 4 sealing and 4 8mm washers when in fact the engines up to 1967 actually had zinc plated copper washers at all 8 top studs. CB77 parts book and fiche shows the 8 followed by the 4 and 4 numbers. 1967 HONDA changed to 4 steel washers at the 4 middle studs held in place with 4 normal nuts not cap nuts. There are others parts which are tough to trace through the years because the of errors made and then repeated over and over. At times I compare same parts with the books/fiche of all these type engines so I can know what's what. ......................lm
68Cb77 wrote:o.k. thanks Ed....I got the sealing washers (looks like steel) from honda. I'll have to re-use the copper ones I guess.....
so just to confirm...the copper ones go on the corners, ( I suppose they seal the oil in) and the steel ones on the middle 4 studs. Why does Honda call the ones I got today (steel) sealing washers?
RIDE IT DON'T HIDE IT!
68Cb77
Post by 68Cb77 » Mon Jul 07, 2008 4:01 pm
well darn, they sent me 90441-286-000...what is that number for?...It doesn't even show up in my parts book. <john>
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
68Cb77
Post by 68Cb77 » Mon Jul 07, 2008 4:02 pm
p.s. my cb77 has 1966 on the wiring harness...so I suppose 8 copper would be fine?
82 Honda XR200R
70 Honda CB750 K0
Post by LOUD MOUSE » Mon Jul 07, 2008 5:24 pm
The parts you received don't cross/supersede to the ones you need as I can find it. You should have 8 to be correct but as HONDA did change to steel in the middle I don't see a problem with the 4 steel in the middle and 4 copper at the corners. ..................lm
68Cb77 wrote:well darn, they sent me 90441-286-000...what is that number for?...It doesn't even show up in my parts book. <john>
68Cb77
Post by 68Cb77 » Tue Jul 08, 2008 6:29 am
o.k., I'm gonna try and get those 2 studs down and go with the 4 and 4 washer set up and hope for the best.....thanks<john>
82 Honda XR200R
70 Honda CB750 K0
garncarz
Post by garncarz » Sat Apr 19, 2014 12:20 pm
I know that this is an old thread but I could use some clarification on this issue please. My CA78 is 1966 but I would like to use the 1967 head stud nut configuration. I hope that this will help me stop snapping studs. As I understand it:
Outside: 1 acorn nuts on top of 1 steel washer each,
Inside: 1 hex nut on top of 1 copper washer each.
Correct?
Thanks.
Post by LOUD MOUSE » Sat Apr 19, 2014 3:07 pm
garncarz wrote:I know that this is an old thread but I could use some clarification on this issue please. My CA78 is 1966 but I would like to use the 1967 head stud nut configuration. I hope that this will help me stop snapping studs. As I understand it:
Outside: 1 acorn nuts on top of 1 (copper) steel washer each,
Inside: 1 hex nut on top of 1 (steel) copper washer each. ......................lm
Correct?
Thanks.
