Camshaft removal help!
Bryanwingen
Post by Bryanwingen » Mon Nov 09, 2015 7:27 pm
Thanks for the quick reply, I'll try that now. Thank you! First time trying the top end, gotta start somewhere.
Bryanwingen
Post by Bryanwingen » Mon Nov 09, 2015 7:42 pm
I'm sorry I have some many questions. This is where I am at now and they don't seem to move anymore. Screw driver is there to show which way they should go out.
apeonwheels
Post by apeonwheels » Mon Nov 09, 2015 9:32 pm
Hi, you are almost done. My cams were easy to pull apart from the head by little force. These cams may be tightened up because the bearings are a non-straight position. If they sit in the housing perfectly then they should come out if you hit gently the bearing outer shell from inside. If they don`t want to, another chance would be to put the whole thing into the oven and warm it up a bit, that may help because the aluminum expands faster than steel. Or, heat up the aluminum around the bearings with a heat gun. They have to come out. G
AlanW
camshaft removal
Post by AlanW » Tue Nov 10, 2015 4:24 am
Bryan,
You are just about there, you are correct that the bearings must be lined up with the holes.
The bearings are all the same size so they will come out but must be lined up, you don't need heat,
Al.
