Raising compression ratio
Hoosier Tom
Greener101
Thanks for the input guys.I really like the gel pads as I also suffer from the disease-no assitol.Living in a rural area the traffic is very light.I will definitely look to other options.I found a 81 Honda GL(?) 500 with the shaft drive.This could give reason to resurrect the old girl....maybe into an electric bike.Greener
Cheburashka
Greener101
Greener
Cylinder size is 152.5 cc
bore diameter is 60mm ( if STD)
Stroke is 54mm
Compression Ratio 9.5:1
Compression ratio is :-
Combustion Chamber Space Divided by (152.5cc + Combustion Chamber space)
Easy enough to work out from that.....
Stroke is 54mm
