engines sieze from sitting ,Why?
conbs
penetrating oil
Post by conbs » Sat Dec 11, 2010 11:42 am
bbap,
There is a thread on this site that discussed penetrating oils with some data which I copied to my files.
Pentrating oil / Average load / Price perfluid ounce
None / 516 pounds /
WD-40 / 238 pounds / $0.25
PB Blaster / 214 pounds / $0.35
Liquid Wrench / 127 pounds / $0.21
Kano Kroil / 106 pounds / $0.75
ATF-Acetone mix / 53 pounds / $0.10
The ATF-Acetone mix was mixed 1 to 1 ratio.
I thought it was pretty impressive. You might try the ATF-Acetone mixture to unstick your pistons.
bbap
Post by bbap » Sat Dec 11, 2010 12:32 pm
Thanks Conbs, I did see that post. I was looking to see if there was a post that dealt with the best way to un-stick the motor such as:
1. Step 1: liberal spray of ATF/Acetone to both cylinders
2. Step 2: Wait 48 hours
3. Step 3: Press firmly on the kick starter (or) put in gear and gently rock bike back and forth
Maybe the better or more typical way is to:
1. Step 2: Remove the motor from the frame
2. Step 3: Remove the ________________
That type of reference from people that have encountered this a few times. I've done this a number of times on vintage motocrosser's, but removing the engine, top end and split of cases appears to be much easier on the single bangers....
mike1969
engine sticking
Post by mike1969 » Sat Dec 11, 2010 2:06 pm
Conbs,What does the "average load" mean? Mike
