CL77 305 Timing And Camshaft Position Question
Honda305rider
Post by Honda305rider » Fri May 18, 2018 4:03 pm
So I'm rebuilding my 1968 305 CL77 engine and this has me stumped...
Lets start with timing.....
With the Rotor at F the camshaft mark is in the 6 o'clock position. Correct?
After 360 degree rotation of the rotor (returned on the F mark) the camshaft mark is at the 12 o'clock position and I need to hold the vise grips so the rotor doesn't turn. Is this correct?
....Onto valve-train/ lash....
I can only check my valve clearance on the T mark for cyl. 2 if the cam is in the correct position, the piston at TDC of course. If the camshaft is not in the correct position i need to roll the engine 180 degrees over and still piston #2 at TDC will allow valve lash to be measured.
Something seems a miss, hope you guys can help...
Thanks,
Chris
Re: CL77 305 Timing And Camshaft Position Question
Post by LOUD MOUSE » Mon Jun 25, 2018 10:20 am
Did you get this answered?. …………………..lm
Honda305rider wrote:So I'm rebuilding my 1968 305 CL77 engine and this has me stumped...
Thanks,
Chris
Thanks,
Chris
G3
Post by G3 » Mon Jun 25, 2018 5:06 pm
Hi Ed,
This is the same poster you responded to on May 27 in a different post. His cam was 180 out.
He actually posted twice on the same topic, but days apart, and evidently all is good with him now.
Post by LOUD MOUSE » Mon Jun 25, 2018 9:23 pm
Thanks for the remind G3. ……………..lm
G3 wrote:Hi Ed,
Honda305rider
Post by Honda305rider » Thu Jun 28, 2018 8:31 pm
All is good in the hood as they say! Bikes been running great! 30 miles on her. Thank
Thanks again for all the help guys
