CB 77 camshaft
CB 77 camshaft
Just starting to learn all about these beauties. I have a 64 CB 77 converted to race spec. Looks and sounds really fine with megga exhausts. An oil leak from the front head joint has prompted a head off job. So far engine looks really clean ( as far as I have got!!) Already I have a question. The cam chain seems to be of the endless variety. I would have preferred to split it and use a joining link but there does not seem to be room for the pin extractor or rivet tool. Is there some tool available to do this or have I got to take out the cams to get the chain off?
You should have room to get a dremel with a small cutoff wheel into the space, then cut the side plates on one of the links. You'll have to remove a link anyway if you plan to reuse the cam chain with a master link. If you do this, you'll need to pack the area with rags to keep the swarf out of the top end. Or you can remove the cams. I would replace the chain with new.
