Cam chain timing
Hondaboy
Cam chain timing
Post by Hondaboy » Wed Jun 29, 2016 8:23 pm
During the rebuild of my bike I installed a new cam chain, rings and valve job. Will the bike run with the timing off a tooth ? It seems sluggish and has a low end miss/hesitation and running rich and blackening the plugs. Could all of this stem from cam timing being off ? I have gone over the carb several times and the carb seems clean and correct jets are installed. Can I use a timing light to check ignition timing to see if I can match the F mark on the flywheel ?
Re: Cam chain timing
Post by LOUD MOUSE » Thu Jun 30, 2016 7:23 am
The engine will also run HOT if a tooth off.
A timing light will help you decide to pull the engine and get the chain correct. .................lm
Hondaboy wrote:During the rebuild of my bike I installed a new cam chain, rings and valve job. Will the bike run with the timing off a tooth ? It seems sluggish and has a low end miss/hesitation and running rich and blackening the plugs. Could all of this stem from cam timing being off ? I have gone over the carb several times and the carb seems clean and correct jets are installed. Can I use a timing light to check ignition timing to see if I can match the F mark on the flywheel ?
Hondaboy
Post by Hondaboy » Thu Jun 30, 2016 8:41 am
If I was a off on the cam timing then the correct F ignition timing will not be able to be achieved using the timing light. Correct ?
Post by LOUD MOUSE » Thu Jun 30, 2016 9:39 am
You are correct.
Are you at the bike?. ...............lm
Hondaboy wrote:If I was a off on the cam timing then the correct F ignition timing will not be able to be achieved using the timing light. Correct ?
Hondaboy
Post by Hondaboy » Thu Jun 30, 2016 10:17 am
I will be in 30min
Post by LOUD MOUSE » Thu Jun 30, 2016 10:21 am
Good deal.
Call me at 830-895-0654 with the points cover and stater cover off. ...................lm
Hondaboy wrote:I will be in 30min
Hondaboy
Post by Hondaboy » Fri Jul 01, 2016 2:32 pm
Trying to call you I am ready to reset timing chain
