Tachometer Cable Oil Seal?
- ojwilliams1
I'm trying to find out if and where I can get a new oil seal for the tachometer drive cable for my recently purchased CB72 Hawk. I have an EBay receipt for a new “Genuine Honda” cable that the previous owner installed and I understand that it should have come with a new seal but as the photo shows the one that’s there is old, cracked and worn. I don't see it anywhere in the parts manual that I have. Any help is appreciated.
- Seal_3.jpg (183.41 KiB) Viewed 3073 times
If it is any help, I cured an oil leak from this location by placing a fibre washer between the cable and the housing. I did not have a seal like yours on my cable.
http://www.honda305.com/forums/excessiv ... 712-7.html
Tachometer cable seal
Hi, standard 7x14x4mm rotary seals work well, remember to place control side towards tacho drive.
PhilD
PhilD
1964 CB72
1964 CB77
1964 CB77
- ojwilliams1
Leak Fixed
Bought from ebay for $3.72 and installed:
"AVX Shaft Oil Seal TC7x14x4 Rubber Lip 7mm/14mm/4mm metric"
Matched old seal perfectly. No more leak. Thanks guys.
OJ Williams
OJ Williams
You are welcome, glad to hear the oil is staying where it's supposed to be. Cheers,
PhilD.
PhilD.
1964 CB72
1964 CB77
1964 CB77
