CB77 doesn't run well, bad compression?
mvdb
Post by mvdb » Tue Jun 04, 2013 5:22 pm
I bought my CB77 a couple years ago, but I haven't had so much time to fix her up.
I got 1 new coil, a condenser and a fresh set of points so I have good sparks now. I adjusted the valves, got the carbs cleaned in an ultrasonic bath and flattened the flanges.
Though she doesn't wanna run fine yet. I got myself a compression tester, plugged it in and kicked the bike over a couple of times. Here's the results.
Left, about 116 PSI
Right, about 87 PSI
Will this be the reason for running poorly?
I'm not really sure what to do next. Spray soapy water and see if the headgasket leaks? Bad valves?
Thanks in advance
cadman
Post by cadman » Tue Jun 04, 2013 6:11 pm
First did you do this with the carbs wide open? If not do it again.
Pour an ounce of Marvel Mystery oil in each cylinder and let it set for a day or two and recheck.
mvdb
Post by mvdb » Tue Jun 04, 2013 9:04 pm
cadman wrote:First did you do this with the carbs wide open? If not do it again.
Thanks for the quick reply.
Yep, throttle WFO! Not sure about the choke position though.
I'm not sure if we have that oil in Europe. Is that for checking the piston rings or something?
It will take a while for me to check this, not sure when I'm home again.
cadman
Post by cadman » Tue Jun 04, 2013 9:42 pm
Throttle wide open choke off.
Marvel Mystery oil or .... something to loosen up the rings. They may be stuck in their groves and causing problems. We also have PB Blaster which is used for loosening rusted bolts - or you might even try WD-40. Let it set for a day or two and then crank with plugs removed to clear and recheck compression. This is essentially a somewhat dry test.
Next would be to put a tablespoon of oil in each cylinder and see what happens. If the compression goes up dramatically probably poor ring sealing - if it goes up marginally then probably valves.
jensey
Post by jensey » Wed Jun 05, 2013 12:04 am
where are you located ?
cadman
Post by cadman » Wed Jun 05, 2013 8:38 am
Marble Falls, Texas
mvdb
Post by mvdb » Wed Jun 05, 2013 6:47 pm
jensey wrote:Hi,
In the Netherlands just like you!
