Hi All:
I am putting back together a 1964 CB77 Superhawk, and I am wondering where the lines from the vent fitting in the top of the cylinder head cover, the two vent fittings next to the carbs, and the one vent fitting on the air filter go to, connect??? Any help would be greatly appreciated.
Thanx, Carl
Vacuum lines and vents?
carlluvscorinne
Re: Vacuum lines and vents?
The top vent passes to the right of the left carb and through the slot in the case cover and 1/4 inch out of the hole behind the drive sprocket.
The 2 vents attach to a plastic "Y" then to the tube on the right side air cleaner. ...lm
carlluvscorinne wrote:Hi All:
Thanx, Carl
carlluvscorinne
Vent tubes
Carl, You read my mind for a question and Ed provided the appropriate answer, as usual. Thanks to both.
Gary
Gary
'65 CL77 Owner
