Would damage occure if I was to flush oil resivore with kerosene or deisel?
Ed
Clean inside of engine.
Goodysnap
I assume you mean while still assembled in running condition. I have done so in the past on many different engines. I ussually add a solvent of your choice to the oil. Drain some off before hand if you choose. I prefer not to exceed 25% dilution. I only run at idle for 10-15 min , then allow to thoroughly drain. Clean out the filter after draining.
To answer your question. If done wrong yes it sure could.
64' CB77
65' CB160
65' CB160
Thanks Goody,
Thinking of only cranking not starting.
Ed
Ed
