Conrod CB77E
Conrod CB77E
Examine the top end of the connecting rod on my CB77E, 1964. <br /><br />The conrod top end seams to be steel towards steel (piston bolt - conrod) without any kind of e.g bronze bearing. <br /><br />Is that a standard conrod rod , a bad construction, restriction from high rpm. etc.<br /><br />Regards /Kuno<br />
Re: Conrod CB77E
That sounds like a stock rod. As far as RPM the stock redline is like 9000rpm they will hold up to higher RPM w/ the right parts.<br /><br />georGe
Re: Conrod CB77E
Thanks georGe, it seems to not be a problem vith the conrods.<br /><br />/Kuno
