CA77 Head Sealing Washers?
Do I see a Bolt rather than a Nut near this leak?
The location as I can tell will require a soft washer/seal "HONDA ALUMINUM" and the Special sort of NUT. .............lm
mca2 wrote:I've noticed oil drops under my '67 CB77. Closer inspection showed some leakage along a the threads of a stud (see picture). If i look at the above pictures this should be position 3?
Any suggestion how to fix this? And does anyone know where the oil's coming from anyway?
I'll see if i can get my hands on this special nut. I've studied my original shop manual and parts list, but it is nearly impossible to spot which nut goes where. But the oil drops seem to prove that at least this one requires such a nut :)LOUD MOUSE wrote:Do I see a Bolt rather than a Nut near this leak?
And yes, the other looks like a bolt. I assume someone found out, a bolt instead of a rod and nut also works. And apart from this leak, it otherwise seems oil tight.
