Oil leak
oldncapilot
Oil leak
Post by oldncapilot » Thu Mar 24, 2011 10:53 pm
Oil is leaking from a gasket under the engine on my CB77. The gasket is under a cover which is held by 5 bolts and the drain plug screws into it. My question is, other than loosing the engine oil, is there any other problem I should be aware of in removing this cover? Also, can this gasket be ordered separately from an engine gasket set and if so, what is it called and where could I buy it? Thanks, Brian.
56_oval
Post by 56_oval » Fri Mar 25, 2011 1:07 am
That's your oil pump. They can be a pain to take off, but you should have too much of an issue. I ended up making a new gasket for mine out off some cheap gasket material from autozone. No leaks yet.
Post by davomoto » Fri Mar 25, 2011 8:30 am
There are two gaskets, on on top of the screen plate, and one on the bottom.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Snakeoil
Post by Snakeoil » Fri Mar 25, 2011 10:40 am
You need to use 1/32" gasket material because the gasket thickness determines the gear mesh for the oil pump. DO NOT USE THICKER MATERIAL. Original gasket was .020-.025 or a little over .5MM.
There are two hollow dowel pins in that align the plate. They are located where the long bolts are on opposite corners. This means the plate has to come down fairly straight. You cannot pry one end and keep pulling down on that one end. Tap with a plastic hammer to loosen the stuck gaskets and then carefully remove without ruining the gasket surface.
After I did mine, I thought about seeing if the local Honda dealer had the correct 0.020 inch thick gasket material. Still might try to find it at a foreign car supply house or the Honda dealer.
regards,
Rob
FAST FRED
New oil pump gaskets
Post by FAST FRED » Fri Mar 25, 2011 1:13 pm
I still have both gaskets in stock, NOS genuine honda, $1.00 each plus $.50 to mail, if you are interested.
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
Dana01
Post by Dana01 » Fri Mar 25, 2011 1:54 pm
... and I do believe they are part of the standard motor gasket set.
Try not to bend the screen's metal flange when dissembling it.
Dana
1966/7 CB-77 Red of course
Snakeoil
Post by Snakeoil » Sat Mar 26, 2011 1:08 pm
The gaskets sets I've seen listed normally say that they do NOT include the oil pump gaskets.
regards,
Rob
