When is it time to resurface Cam adjuster wheel?
OldStan
Post by OldStan » Fri Jan 07, 2011 12:29 pm
I know this question has been asked before, but I haven't found an answer. I've got a cam chain idler wheel that appears to be in good shape except for some small denting in the center rib. There are no cracks. Is it bad enough to resurface or am I better off leaving it alone? I'm concerned I may do more damage than good.
need resurfacing?
need resurfacing?
63 CA78
GeorgeP1111
Re: When is it time to resurface Cam adjuster wheel?
Post by GeorgeP1111 » Fri Jan 07, 2011 2:27 pm
OldStan wrote:I know this question has been asked before, but I haven't found an answer. I've got a cam chain idler wheel that appears to be in good shape except for some small denting in the center rib. There are no cracks. Is it bad enough to resurface or am I better off leaving it alone? I'm concerned I may do more damage than good.
I too would like to hear what the general opinion is.
Mine is marginally better than yours, but does have marks (small chips) on the side of the center raised part where the white reflection is on your photo. When I cracked my motor open I found the cam chain guide roller was just floating in the chain because the whole center of it's guide pin was gone. I'm assuming that this caused the chain to be rubbing on one side of the tension roller causing the chips I see.
It sure would be great to come up with some way of making the tension roller removable with the option for replacement.
George
Post by davomoto » Fri Jan 07, 2011 2:28 pm
Stan, if you feel confident doing it, I would recommend cleaning your wheel up. If you don't it will get worse, as the chain will bump along in those grooves.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
OldStan
Post by OldStan » Fri Jan 07, 2011 2:36 pm
Thanks Davo. I think I'll give it a shot. I have my original one which has 1/2 the ridge missing and has flat spots, so I can test my methods on it without worrying about it.
63 CA78
