Cracked Case?
kyle91987
Cracked Case?
Post by kyle91987 » Fri Jun 11, 2010 8:24 pm
I was breaking down the engine of my CA77 to rebuild it and examine anything that needed any attention and found this. I can feel it with my fingernail and I'm not a metallurgy expert so I don't know if this is a crack in the case or just a casting flaw. Have you seen anything like this? Should I have it welded while I have it apart?
Edit: It's the upper crank case and the crack I'm referring to is the inside. I posted the outside to see if anyone could see something I missed.
Post by davomoto » Fri Jun 11, 2010 8:26 pm
Casting mark, they all have it
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
kyle91987
Post by kyle91987 » Sat Jun 12, 2010 10:38 am
All in the same area?
Post by davomoto » Sat Jun 12, 2010 10:39 am
Yep
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Loudo
me too
Post by Loudo » Mon Jun 14, 2010 5:11 pm
I posed the same question and attached a photo in the Restorations area concerning my bike. Though I didn't get an answer from anyone at the time, it seems I have the answer now. I think the crack I was concerned with appears in the same location as yours.
kyle91987
Post by kyle91987 » Mon Jun 14, 2010 8:57 pm
Well, I finally just took a grinder too and sanded the "crack" off. It seems like it was just a casting flaw as it left no lines at all after some light sanding.
