I have a CB160 that spent most of it's life in a dry basement, out of the destructive effects of sunlight. The red paint is the same color under the tank panels as it is everwhere else on the bike. The silver paint is also unfaded. Under the seat is same as front fender and rear exposed porting of rear fender.
So, I needed to touch up an area on the rear fender that has been hit with battery acid at sometime in the past. I spent sometime at the Duplicolor display in Advanced Auto, and with the help of the wife as a double check, found a nearly perfect match for the silver paint on the fender. Here are specs for the paint. It's a GM OEM paint touch-up spray paint.
Duplicolor BGM0508
Ultra Silver Metallic
GM numbers 95-WA8867, 96- WA8867
Replaces T191
GM PA1107
UPC 26916 71424
Code on can bottom – EBGM0508/HL0232WJ
regards,
Rob
