Here's some pics before clean up.
Mileage wasn't outrageous either
The bike is titled as a '69, but the early VIN and other obvious details makes it a '68 build. Note the rounded taillight and no starter. The starter and rectangular taillight (top edge) came in '69 and are referred to by some collectors as K1 models. However Honda only recognizes the K0 which was sold from Jan 1968 until being replaced by the K3 version in May of '69. Trivia for the day: The CL175 K0 is the only 5 spd "sloper" motor Honda made, replacing the CL160 4 spd model.
I'll be doing a restoration of my '66 CL160 next since they are both in similar condition and nearly identical looking bikes.
The CL160 came from Buffalo, NY so has some pitting but is also complete and original except paint. I've already got a replacement tank for it.
Here's a pic of my '66 CL160.
And just for the heck of it, so you can see the design progression, a pic of my '69 CL175 K3, which is one of the rarest honda scramblers out there. It came with the newer vertical twin engine. The were very much a cross between a CL and the new SL's that were to soon be released. Note the SL type metal front fender.
And near the end of the model run, My Magna Red '72 K6 version of the CL175.
Back to the project.
I don't like to waste time with discussion of the tear down, as it was pretty routine for me, bagging and labeling every fastener and pictures to view if needed later.
But before it's torn down to far, I like to fire them up to see if the motor is solid, without any unusual noises etc. In this clip, you'll see it appears to be smoking pretty bad. But not to worry, often times when a bike sits as long as this one has, the rings become stuck. A little time running and some well placed chemicals usually free them right up and this case was no exception.
https://www.youtube.com/watch?v=_Cva5BJIZ_A
Here's the starting point after painting the frame and misc bits black.
Back soon with the start of the assembly......
