My CB 160 gas cock leaks. It was tight when I took over the bike... became intermittent... now seems to drip consistently when the cock is off. The leak is through the valve assy... the tank gasket it tight. Can't see anything wrong with anything in the disassembled valve / cock assy. Everything appears pristine, the four hole rubber gasket seems new and undamaged, the washer spring looks fine, and the outer plate faultless. But it leaks.
Any experience or suggestions..?
thanks
peter
CB 160 Gas Cock...
Do the petcock mounting screws have sealing washers under the heads? Gas will run down the threads(by-passing the shutoff valve) unless there is a washer under the head of the screw.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
