CB160 engine noises - need some personal calibration
CB160, CB350, CB360, CB450
Jlovvorn
Post by Jlovvorn » Sun Nov 11, 2012 11:07 pm
Thanks! I am going to redo it now for sure.
teazer
Post by teazer » Thu Feb 07, 2013 1:33 am
correct, but try rotating 360degrees and repeat the process. Loosen the lock nut, loosen the bolt and watch to see if the plunger moves in. If necessary, apply tension with a wrench on the crank applying pressure in reverse to make sure the rear side of the cam chain is under zero tension.
