CB160 - Timing Question
CB160, CB350, CB360, CB450
acurtiss
Post by acurtiss » Tue Aug 28, 2007 9:29 am
Well I'm possibly more confused than I was before I asked the question! Kidding, I *think* I have a sense of how I should be checking the timing. But I sure would like to hear a nice loud backfire out of a muffler to confirm I'm at least on the right track.
swampyankee
Post by swampyankee » Tue Aug 28, 2007 9:53 am
Don't quote me on the backwards running thing. I'm still looking for confirmation and was hoping emo could help verify it - or not.
Bikes:
'79 BMW R100RS
'03 HD Sportster 883R
'66 Benelli Sprite
'64 Honda CL72/CL77 motor
Post by LOUD MOUSE » Tue Aug 28, 2007 10:48 am
The 160 and 175 engines have 360 cranks and one set of points so if ya time the left side to "F" ya should get a bang. If ya turn the drank left ya will open the points on the front of the cam lobe where if ya turn the crank right ya will be on the back side which won't be correct. Ya can't assume the 250/305 trans are at all like the ones in the 160/175 because of the side of the engine the final drive sprocket is on. Totally different clusters in there. .........lm
swampyankee wrote:Don't quote me on the backwards running thing. I'm still looking for confirmation and was hoping emo could help verify it - or not.
swampyankee
Post by swampyankee » Tue Aug 28, 2007 11:05 am
Here's how to know for sure (and prove whether I'm way off in left field). Kick the motor over with the kick start and observe which direction the stator turns. Then rotate the stator in that direction to set the static timing.
Let me know what you get. My curiosity is killing me!
Bikes:
'79 BMW R100RS
'66 Benelli Sprite
acurtiss
Post by acurtiss » Tue Aug 28, 2007 11:14 am
It turns counter-clockwise. Also indicated by arrow on timing rotor... :) Indeed I had been setting the points 90 degrees off, but still no pop. A related question: do the plugs fire simultaneously? I don't know the history of this bike so it's impossible to rely on what I was given. It has a single coil, with upper and lower plug wires. Both wires are getting a strong spark, and the plugs are also new NGKs.
Post by LOUD MOUSE » Tue Aug 28, 2007 11:16 am
Both plugs do fire together.
It's the valve timing which causes only one cylinder at a time to fire. ...............lm
acurtiss wrote:It turns counter-clockwise. Also indicated by arrow on timing rotor... :) Indeed I had been setting the points 90 degrees off, but still no pop. A related question: do the plugs fire simultaneously? I don't know the history of this bike so it's impossible to rely on what I was given. It has a single coil, with upper and lower plug wires. Both wires are getting a strong spark, and the plugs are also new NGKs.
acurtiss
Post by acurtiss » Tue Aug 28, 2007 12:03 pm
That's what I thought. So switching the wires around is a waste of time :)
Is there any way to check valve timing without dropping the engine?
