Page 4 of 4
Posted: Sun Jan 19, 2014 1:57 pm
by Hoosier Tom
Did you check the oil pump behind the right side cover for any obstruction to the intake screen and for proper function?
HT
Posted: Sun Jan 19, 2014 3:25 pm
by Jlovvorn
Will check that next Tom.
Put a fine wire into each oil passage under base gasket.
Right side went in a good two to three inches.
Left side went in one inch and stopped.
Is that normal, or should the left go further?
Posted: Sun Jan 19, 2014 3:59 pm
by Hoosier Tom
I see you have been posting this problem on the Honda twins site and Steve has offered help over the phone. I would take him up on it.
HT
Posted: Sun Jan 19, 2014 5:12 pm
by Jlovvorn
Yes, we spoke by phone a bit ago.
My first two stops are confirming the pump and those two passages under the base gasket.
chirping CB160
Posted: Sun Jan 19, 2014 11:02 pm
by bikedoctor99
Russ,
Sorry to read that the top end is toasted, but as you know it can be rebuilt after a meticulous and methodical cleaning.
However you should determine why your motor lost its oil distribution.
Keep us posted.
Allan
Posted: Fri Mar 21, 2014 7:50 am
by Jlovvorn
Update: I found a layer of steel wool shavings stuck to the bottom of the oil pump, coating the screen. It peeled off like dust on a dryer vent.
Before I knew better, I used steel wool to clean the engine cases when they were apart.
I learned this was a really bad idea half way through, and thought I blew it all out and rinsed it out, but apparently not.
I have finished flushing everything and the engine is back together with NOS cam and tappets.
Hoping to get it started this weekend.
Posted: Sat May 03, 2014 6:38 pm
by Jlovvorn
Bike is all finished.
Had horrible time with carbs, as has been the case since I got the bike.
Bolted on PE22 carbs this weekend, and zoom! Idles and runs great.
Wondering if PE22 would be a possible option on my 305, which also has very cranky carbs.
Here it is running https://flic.kr/p/nrLnZm
