Chunk missing from engine case
CB160, CB350, CB360, CB450
Jlovvorn
Post by Jlovvorn » Mon Oct 29, 2012 4:13 pm
Thanks. I gave it a good try alreadym, but must be missing something.
Will work on it some more.
Snakeoil
Post by Snakeoil » Mon Oct 29, 2012 10:03 pm
It might be a plain type of retaining ring with no obvious way to spread it to remove it. Clean it well and you should see a small gap. If this is the case, you will need to get into that gap to lift one end and get it started out of the groove. A knife that you don't mind damaging the edge will probably do the trick.
Please take pics of what you find and post.
And go get yourself a can of BrakeKleen. It's degreaser with a high pressure propellant that will blast areas clean. Toothbrush is helpful as well.
regards,
Rob
Jlovvorn
Post by Jlovvorn » Tue Oct 30, 2012 6:26 pm
Ok, I got the snap ring off. It did have two little tabs with holes. Tiny circilp pliers did it.
Last question - there is a third seal in the far upper left, with a bolt over it and some wiring.
Do I just ratchet that bolt off?
Or is there anything I need to worry about here to get at it?
