All lighting is now LED with a rechargeable battery pack. The front light is a flood style lamp that is extremely bright and the rear lighting is an 6" led strip from DRC. I also fitted a front brake switch I drilled into the handlebar lever that works perfectly! I'll get more pics of that up shortly. The gas tank sides have been hand rubbed to a neat brushed look, still chrome in the pics. I am getting the motor put back together this weekend. Finally found a set of .25 over rings from an eBay seller for only $30! I am doing a kick start only conversion and battery delete. So trying to get as much research as possible for this in terms of that. This build is meant to mess around on the back roads here in WA and to take to vintage track days here and there!
I need to fab up a fork brace and re-do the exhaust. I'll get pics added as soon as I can! Then onto the real fun....electrical :)
