Page 12 of 15
Posted: Mon Dec 15, 2014 5:56 pm
by jugger18
Aslo what sort of tool should I use on the knurled shaft nut?
Posted: Mon Dec 15, 2014 7:34 pm
by 48lesco
Use a screwdriver you're not particularly fond of and a hammer. Jam the sprocket with a block of wood. The nut is most likely left-handed thread. Don't forget to take the nut off the left (tach) side of the camshaft. After all that is loose, use a soft drift or brass stock or something like that and tap, tap, tap, tap, tap, tap, .... tap, tap, tap (you get the idea) on the outer bearing races. Usually easiest to tap the the inner bearing through both holes, or I think you might be able to press the camshaft out of it while the inner bearing is loose between the mounts. I don't think it's wise to re-use those bearings but you probably could. Usually a 2-3 beer affair to get both sides out.
-48
Posted: Mon Dec 15, 2014 7:36 pm
by LOUD MOUSE
Ya can call me at 830-895-0654 and I'll discuss this with ya. ............lm
jugger18 wrote:Thanks guys. Going to attempt camshaft diss assembly tonight. IS there a detailed writeup here somewhere?
Posted: Mon Dec 15, 2014 8:04 pm
by jugger18
Thanks LM. I will give it a go and if I run into problems I will give you call. How lae is it ok to call there. I am central time
Posted: Mon Dec 15, 2014 8:17 pm
by LOUD MOUSE
I'm Central Time and call before ya start the job. .........
Now would be good. ...................lm
jugger18 wrote:Thanks LM. I will give it a go and if I run into problems I will give you call. How lae is it ok to call there. I am central time
Posted: Mon Dec 15, 2014 8:53 pm
by jugger18
Sorry LM. Had to have dinner with the family. I don't want to call too late if it may take some time. I would like to make sure I have all the tools I will need before hand so I dont waste your time. Maybe tomorrow night would be better?
Posted: Mon Dec 15, 2014 9:38 pm
by LOUD MOUSE
Call B4 you start. ........lm'
jugger18 wrote:Sorry LM. Had to have dinner with the family. I don't want to call too late if it may take some time. I would like to make sure I have all the tools I will need before hand so I dont waste your time. Maybe tomorrow night would be better?
