64 CB77 pulled today after 25 yrs
Thanks for the information HT. I'm still learning the nomenclature but I ll get it right I saw a video on YouTube of a guy rebuilding the clutch and I intend to do the same even though the disks are not stuck.
Re: 64 CB77 pulled today after 25 yrs
i hope your Pistons aren't hard to free up. Good luck.Merz64cb77 wrote:Thanks for the information HT. I'm still learning the nomenclature but I ll get it right I saw a video on YouTube of a guy rebuilding the clutch and I intend to do the same even though the disks are not stuck.
HT
Good start
You've got a lot better starting point than half of the 305s I've brought back to life! Good luck, be patient...............................D
Thanks again gents. I'm crossing my fingers too.
Today I tried to clean the inside of the fuel tank using electrolysis following the instructions on this site and had some success but there is still a layer of rust/varnish inside the tank. There seem to be a lot of products to remove the rust/varnish. Have any of you had success with these products?
1. Evaporust
2. Muriatic Acid
3. Lacquer Thinner
4. POR-15 cleaner and degreaser only (I don't want to exopxy the inside of the tank)
1. Evaporust
2. Muriatic Acid
3. Lacquer Thinner
After trying the POR cleaner, I ended up using "toilet bowl cleaner" which, effectively muriatic acid. Worked a treat.
Merz64cb77 wrote:Today I tried to clean the inside of the fuel tank using electrolysis following the instructions on this site and had some success but there is still a layer of rust/varnish inside the tank. There seem to be a lot of products to remove the rust/varnish. Have any of you had success with these products?
1. Evaporust
2. Muriatic Acid
3. Lacquer Thinner
