Steverino's CB77
Superchicken
Post by Superchicken » Fri Dec 19, 2014 8:37 am
That bike is nice! I see the car is from that direction is much higher.
Steverino
Post by Steverino » Fri Dec 19, 2014 2:53 pm
The front tire is a Yokohama Speed Master 3.25 and the rear is a Cheng Ching (sp?) 3.50. Yes, now that I've had a closer look they look a bit too large. I'm a little surprised the original owner wore out two rear tires in 4500 miles.
Post by LOUD MOUSE » Fri Dec 19, 2014 3:05 pm
Not original for sure. ............lm
Steverino wrote:The front tire is a Yokohama Speed Master 3.25 and the rear is a Cheng Ching (sp?) 3.50. Yes, now that I've had a closer look they look a bit too large. I'm a little surprised the original owner wore out two rear tires in 4500 miles.
Post by G-Man » Fri Dec 19, 2014 3:25 pm
You will get a better clue on the mileage when you look inside the engine. If it is on standard bore the mileage could be correct. If it has been bored I would suspect that the speedo has been replaced at some time.
After 40 years it is difficult to determine the history. Almost anything, including the wheels, could have been replaced.
Steverino
Post by Steverino » Mon Jan 05, 2015 7:27 pm
I am nearing completion on Jimmy's Scrambler. By far, the most challenging part of the refurb was getting an acceptable paint finish. I finally found Duplicolor Acrylic Lacquer Base and Clear. It turned out great and looks as close to Factory as anything I've seen. I just have to finish the carbs and I will be able to give him his bike back and then I can get started on my CB77. When I got the SuperHawk it was missing the side covers and the crankcase cover. Here is a pic with replacements installed. I was surprised at the color when the side cover showed up. I thought they were all silver.
ImageCB77 with side and engine covers by stevesteverinomeister, on Flickr
sarals
Post by sarals » Thu Jan 08, 2015 11:27 am
Apparently someone painted them gold!
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
Steverino
Post by Steverino » Thu Jan 08, 2015 10:25 pm
Thank You Sarals I have a lot to learn about 305's! I was thinking Honda must of built some Gold ones.
Steve
