1st time building anything.
Johnny5
Post by Johnny5 » Sat Oct 01, 2011 1:54 pm
Now I'm having coil issues, I believe I need a new one, I hooked a car coil up instead to make sure the condenser was working right and I have spark, but when I hook the correct coil back up it only sparks once and a while and not very strong...SO now looking for a replacement coil.
bbap
Post by bbap » Sat Oct 01, 2011 6:51 pm
I had a similar problem with spark on my Dream. It was running fine and after about a 5 mile run, it just quit. Checked points and cleaned them well but no difference. Pulled spark plugs and one had no spark and the other weak spark. On my coil, I can pull the wires and swap them out and the problem followed. I ordered a coil (cool looking chrome one) from JC Whitney and it came about two hours ago. Hooked up and spark on both sides and a running motorcycle a few minutes latter. I think it cost me about $44 delivered. Note there is a 15% off coupon on line that I found that payed for the shipping :)
Steve
Johnny5 wrote:Now I'm having coil issues, I believe I need a new one, I hooked a car coil up instead to make sure the condenser was working right and I have spark, but when I hook the correct coil back up it only sparks once and a while and not very strong...SO now looking for a replacement coil.
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
Johnny5
Post by Johnny5 » Sat Oct 01, 2011 9:19 pm
bbap wrote:I had a similar problem with spark on my Dream. It was running fine and after about a 5 mile run, it just quit. Checked points and cleaned them well but no difference. Pulled spark plugs and one had no spark and the other weak spark. On my coil, I can pull the wires and swap them out and the problem followed. I ordered a coil (cool looking chrome one) from JC Whitney and it came about two hours ago. Hooked up and spark on both sides and a running motorcycle a few minutes latter. I think it cost me about $44 delivered. Note there is a 15% off coupon on line that I found that payed for the shipping :)
Steve
Awesomeeeee!! That sounds like a good plan and I suspect the coil because its it awful shape and is original to the bike...and I changed the condenser cause I had a brand new one just sitting around.
Johnny5
Post by Johnny5 » Sat Oct 01, 2011 9:24 pm
Steve
You have a link to the coil you got???
bbap
Post by bbap » Sat Oct 01, 2011 9:54 pm
Here's the link: https://www.jcwhitney.com/ignition-coil ... 343y1964j1
SKU Number: 1JA 013085
It comes with a small quantity of coil wire but it is not enough. You will need about 3.25 feet to do both sides. It also comes with a bracket that I did not use. I used the bracket that was on my previous coil.
Here's a "Promo Code" that you have to use quickly: FRSH39 (they sent it to me right after I ordered my coil. I think it expires on Tuesday and gives you free shipping). Hope you can use it.
Steve
_____________________
Steve
Johnny5
Post by Johnny5 » Sun Oct 02, 2011 12:58 pm
bbap wrote:Here's the link: https://www.jcwhitney.com/ignition-coil ... 343y1964j1
Steve
Steve
Just placed an order for the coil!!! The free shipping code worked, thank you very much!! Maybe now I can have the bike ready for Biketoberfest in Daytona the 13th!
bbap
Post by bbap » Sun Oct 02, 2011 1:58 pm
Steve
Steve
Cool, hopefully it will work out for you. I'd suggest getting new spark plug wires if your using original equipment.
Steve
