NEW 1967 CB77 OWNER
Tim Miller
Post by Tim Miller » Mon Mar 27, 2017 1:27 pm
If you need help? I can rebuild your advancer to fix loose rivets and provide proper total timing.
Just PM me.
Tim
zads wrote:I'm putting the camshaft back into the cylinder head. I wanted to make sure the parts I'm using are okay. One camshaft looks a little discolored/ worn (see photo).
I checked the sprocket for any movement due to loose rivets and it is fine. There is less than.1" play in the weights, should I try and tighten the springs? The thin neoprene layer that is on the pegs under the weights appears to be worn down where the metal makes contact, is this a big issue? I tried taking a photo of this.
