Thanks LM.LOUD MOUSE wrote:Yes. They went to 12mm D8XX. ...................lm
darboots wrote:LOUD MOUSE wrote:Does it have 10mm plugs?. ....................;lm
darboots wrote:So, the green wire from the ignition switch is 12v live when the keyswitch is in positions for lighting (III & IV). I assume therefore, that one of the two wires to connect there is the light switch feed, and the other must be for the pilot light/speedo backlight? I'm still unsure how to connect in the high beam indicator as this is a '61 bike and therefore shouldn't have one in the speedo.
In other developments, I've set all the static timing, and after many incidents of the carb over-flowing (stuck floats), cannot get the bike to start. I don't seem to have a fat spark on either plug, but do get a spark. Plugs are CR8EB - D8HA's do not fit - is this because the early bikes used a different head? What plugs should be there?
I'm not convinced I'm getting fuel/air into the cylinders, although the float height is set to ~26.5mm (PW22). The PO seems to have fitted new jets throughout, but I've also ordered a jet cleaner so I can poke any debris out of the jets as all parts of the bike have all sat around for ~5-10 years.
Yeah, 10mm thread size. Was this changed on later models?
So is the CR8x the recommended plug for the earlier CA77 models?
