CA77 and CL77 Projects
2manyhbys
Post by 2manyhbys » Thu May 08, 2014 9:20 pm
Hi all. Here are a couple of pictures of two new projects I picked up recently.
The 1965 CA77 is in pretty good shape and runs well with over 30K miles on it. I'm not sure if the engine has been rebuilt or not but I suspect it has. This one's going to stay together for a while until the CL is finished.
The 1967 CL77 looks pretty good from 30', but the closer you get, the more you notice that things aren't quite right. The 9K showing on the odometer might be a little off. After a little research, it looks like the fenders should be chrome (frame 1062xxx), the side cases are missing chunks, the swing arm is badly cracked, every part that has a fin has one or more broken, the chain guard is missing... and so on. On the bright side, the headlight works.
I have a few other projects in the works so these may be a little slow, but I thought I'd get started anyway.
sarals
Post by sarals » Thu May 08, 2014 10:08 pm
Nice! Great foundations. Good thing about the headlight on CL77 ;) Do you suppose it had been raced?
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
2manyhbys
Post by 2manyhbys » Sun May 11, 2014 1:16 am
I don't think it has been raced but you never know. It was definitely ridden hard and put away wet.
I split the engine this evening and didn't find anything I wasn't expecting. The internals look pretty good and there weren't any parts flopping around inside. There is a large chunk missing from the lower case half that looks like a lot of work to weld so I'll have to replace the bottom half. The top half seems to be ok, thankfully, as that's the one with the serial number.
The piston wrist pins are worn which I'm sure means the small end of the rods are worn. I didn't notice if the rods are bushed or not before I left the shop but hopefully they are and that will be an easy fix - unless wrist pins are hard to find.
I got a call from a guy nearby who has a seized 305 engine for $25 - I said of course I would take it. Hopefully it will have enough good parts so I can end up with close to a complete engine.
malcolmgb
Post by malcolmgb » Sun May 11, 2014 8:05 am
I believe cases shouldn't be mixed, they were machined as pairs.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by LOUD MOUSE » Sun May 11, 2014 3:45 pm
Any lower case will fit the C/CA/CB/CL72/77 top case.
What you don't want is a early lower without the mount locations for the primary chain tension wheel. . ..........lm
malcolmgb wrote:I believe cases shouldn't be mixed, they were machined as pairs.
2manyhbys
Post by 2manyhbys » Mon May 12, 2014 11:48 pm
LOUD MOUSE wrote:Any lower case will fit the C/CA/CB/CL72/77 top case.
I do have another lower case half from a CA77 but it's still in a parts bike. Once I get the engine out and dismembered, I'll check the fit. If the case halves can be intermixed, I'm assuming they were machined as a pair at the factory but close enough tolerances were used that they could be swapped out.
I spent the evening ramping up with a shipment of zinc plating chemicals from Caswell. So far, so good. I'm impressed with the results. I'll share some pictures soon.
Post by LOUD MOUSE » Tue May 13, 2014 12:27 am
The cases were not made as a matched set. .................lm
