Anybody have the neutral light rubber connector for the 3W bulb that goes on the bottom of the indicator in the headlight? Even the whole wiring harness is OK.
Can Paypal
Thanks
Need rubber neutral light bulb holder CL77
- Contact:
Neutral Rubber
That rubber was used on several other bikes. I wonder if Honda would have it. It would be under a different number and I think you have to buy the whole assembly to get it.
Someone found a lawn mower boot that works. I put up a post a while back with the part number in it. Its cheap and works great. Search this site.
Also, you may check to see if there is a repop from the guy in CA. I think I may have seen one on ebay. Hope that helps.
Re: Need rubber neutral light bulb holder CL77
You mean this?:eyedragaknee wrote:Anybody have the neutral light rubber connector for the 3W bulb that goes on the bottom of the indicator in the headlight? Even the whole wiring harness is OK.
Can Paypal
Thanks
http://www.classichondarestoration.com/ ... d_287.html
1965 CA77Dream
- Contact:
THAT IS IT!!!
VERY much appreciated.
Thanks all
Thanks all
