For an early, small brake Rear Wheel with the 17mm axle I need
1. Spacer that is inside the wheel and is part # 42313-273-010. Goes against the collar that goes through the bearing in the sprocket flange and on the other side goes up against the spacer with the 3 metal tangs on each end.
2. An axle nut for the 17mm axle. #90306-273-000
3. 1 of the 4 wierd bolts that attach the sprocket to the sprocket flange. #90128-273-000
4. Chain adjuster for the 17mm axle. I think the one I need should have a slot for the axle, but one with a round hole might work, too. I don't think the Honda parts manual identifies this correctly and I am not sure of the actual part number.
5. 1 outside spoke and nut. #97506-621641 My rim and other spokes are in great shape.
Appreciate any help anyone can give.
CL77 early rear wheel parts
Re: CL77 early rear wheel parts
YA BOUNCE AROUND TO MUCH/QUICK FOR ME.
I TOLD YA I HAD SOME OF THE PARTS.
NOW I SEE THIS.
I JUST REALIZED I SOLD ALL THE PARTS I THOUGHT I HAD EARLIER.
'GOOD LUCK'. ..........lm
NOW I SEE THIS.
conbs wrote:For an early, small brake Rear Wheel with the 17mm axle I need
