Dynamo Cover Screw
Re: Dynamo cover screw 5mm, .90 pitch, 12mm long
Post by G-Man » Thu Mar 24, 2016 8:47 am
Good work. Can you reveal the vendor, please?
eamartin wrote:The screws arrived and I believe they will work. The pitch is correct. Screws are 15mm as opposed to the 12mm I removed from the bike. I have not checked yet to see the depth of the case holes. If they're not deep enough I'll just shorten the new 15mm screws. At this point, these new screws from the eBay vendor appear to be a good solution.
eamartin
Post by eamartin » Thu Mar 24, 2016 9:02 am
"genuinenos.com" I bought the screws from them through eBay. And I'll check this weekend for fit and report back.
eamartin
Post by eamartin » Sat Mar 26, 2016 5:57 pm
I installed the screws from GenuineNOS.com and they fit and look fine. I had been concerned about adequate thread depth in the case since the original screws were 12mm long while the replacements are 15mm. I have not turned over the motor since installing the screws. I was wondering what's on the back side of the case where the screw holes are located. Will the additional 3mm interfere with any moving parts on the inside of the case? Can anyone answer that? Or, should I shorten all the screws to be safe?
