Need a forken lock and key
Locks
The fork locks and ignition locks are very easy to pick. They can be picked any number of ways. You can use any key that will fit into the lock, like an ignition key that is a different number, turn it lightly in the unlocking direction and pull it in and out while giving it that constant unlocking motion. This can set the tumblers and unlock the lock. It might take a little time to get it just right but it can be done and is much better than breaking the lock or drilling it out.
Look up how to pick a lock and the dream ignition and or fork lock will be the easiest lock you ever pick.
jack smith
I think you should search on internet for the keys and lock . Or you should hire an experienced locksmith which can help . these two ways are easy to sort out your problem[/url]
- FluteTears
Re: Locks
I have used this method in the past it works I also like to but some graphite powder in the lock as it may be gummed up.NBD925 wrote:The fork locks and ignition locks are very easy to pick. They can be picked any number of ways. You can use any key that will fit into the lock, like an ignition key that is a different number, turn it lightly in the unlocking direction and pull it in and out while giving it that constant unlocking motion. This can set the tumblers and unlock the lock. It might take a little time to get it just right but it can be done and is much better than breaking the lock or drilling it out.
Also the last keys I had made was at
The key guy is Todd
Ybarra......Security Plus Locksmith; 4145 West Loomis Road;
Greenfield, WI 53221 Phone: 414-282-7778 email: cudaonline@gmail.com
or try www.securitypluslocksmith.com
I called him with my key numbers and in about a week I had working keys for my bike.
He has been able to get me hard to find keys for my bike and I just want to share with the group.
Check him out not sure if he can help now this was years ago but worth a shot.
1974 CT90
1964 CA77
1964 CA77
I haven't used it by own , talking about lock picking i always hire Locksmith to do such task. This can reduce the stress of opening and repairing the whole lock. Locksmith have equipment through which they can easily pick locks and repair it.
denisthompson
Re: Locks
It will take more time to break or drill the lock by own. Call the Locksmith and repair it is the best solution.NBD925 wrote:The fork locks and ignition locks are very easy to pick. They can be picked any number of ways. You can use any key that will fit into the lock, like an ignition key that is a different number, turn it lightly in the unlocking direction and pull it in and out while giving it that constant unlocking motion. This can set the tumblers and unlock the lock. It might take a little time to get it just right but it can be done and is much better than breaking the lock or drilling it out.
OldScrambler
MarkedBanana
If someone are still looking for a proper lock i bought this http://www.ebay.ca/itm/Honda-NOS-NEW-35 ... 3612cb742d one and so far it works smoothly. The only issue i had was installing the lock in a handlebar. That Goddamn thing were a 1mm wider so i had to call a locksmith to do that for me as i don't have grinding wheels for my DeWalt DC 759
