Cl77 Crank shaft
GORDON BROWN
CL crank
Post by GORDON BROWN » Tue Feb 26, 2019 3:39 am
Hello Mike
Graham has answered the questions, unfortunately I am a bit away from Norfolk, near Edinburgh. If you don't want to fit a new end to what you have I will see what I have.
Gordon
Re: CL crank
Post by G-Man » Tue Feb 26, 2019 3:48 am
I can probably find you a fresh crank end and fit it for you if your Engineering shop cannot help.
GORDON BROWN wrote:Hello Mike
Gordon
thepunisher2007
Post by thepunisher2007 » Tue Feb 26, 2019 1:54 pm
apologies for the reply delay and thanks for the help
ill pm you g if that’s ok.
Post by G-Man » Tue Feb 26, 2019 2:16 pm
Yes - no problem.
thepunisher2007 wrote:apologies for the reply delay and thanks for the help
Post by G-Man » Fri Mar 22, 2019 3:51 pm
I got the crank yesterday afternoon and pulled off the generator side web. The big end cage looked a bit horrible and one or two rollers were damaged but the rod and big end pin looked fine.
I didn't have a CL77 generator-side web so I used a CB77 part and blocked off the oil hole.
Having done that side I decided that I couldn't leave the other side of the crank untouched. The other big end had the same nasty-looking wear on the cage but the rollers looked fine. In went another fresh cage after a good clean up.
Everything went back nicely and trued up without any drama. It should do the job for the forseeable future.
sixtiescycle
Re: Cl77 Crank shaft
Post by sixtiescycle » Thu Jul 18, 2019 9:43 am
thepunisher2007 wrote: has a tap snapped off in the internal thread which is proving impossible to get out.
thanks
Mike
Haven't been here much since the spam, I have removed several taps and broken bolts over the years with a plasma cutter, pretty much washes the the bolt out with damaging the threads. The tap you just cut through the center.
Dick
Dick Johnson
'61 CB92
'63 domestic CL72 Type 2
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
AlanW
Post by AlanW » Sun Jul 21, 2019 3:46 pm
Please do NOT go anywhere near it with a plasma cutter, you could easily wreck it. I have been in the fabrication industry all my life and have many years experience with these machines and would not attempt it on one of my cranks.
I suggest you go to you tube and look at methods of broken tap removal.
Hope this helps, Al.
