I'm helping my father rebuild the electrical system on a 1965 CL77, and I need a connection diagram for the 3 position combination/ignition switch.
I'm using the following wiring diagram:
http://www.honda305.com/forums/download.php?id=5418
Which has a switch connection diagram - but it is missing one terminal. So basically I need to know how the "charge" terminal connects in each of the two positions.
Also which position is the "run" position and which is the "parking lights" position?
1965 CL77 3 position combination switch wiring
My understanding is that the switch does not do anything with the CHG wires, besides connect them together. You can put an ohm meter to the white and red wires on the back of the switch. You'll get continuity when the switch is in tail light position. There are other more electically inclined members that may rifute some of this info!
Davo
Davo
