Ground strap? 1966 CB77
There is a ground strap attached at the top fwd engine mount. The problem is that the other end is hanging loose. Where is it supposed to connect to? I'm new on here and did a search to no avail. Thanks
Re: Ground strap? 1966 CB77
I suspect ya have a CB77 although ya didn't say.
It attaches to the bottom of the right coil at the rear bolt holding the condenser. .......lm
cleg wrote:There is a ground strap attached at the top fwd engine mount. The problem is that the other end is hanging loose. Where is it supposed to connect to? I'm new on here and did a search to no avail. Thanks
