Does this battery work? 65 CA77
jstark
Post by jstark » Thu Jun 15, 2017 1:59 pm
Hi there,
I have a 1965 Dream 305, I believe that makes it a CA77. It has a dead battery on it, but I'm not sure it's the correct one for this bike. It's a BikeMaster BB9L-B https://bikemaster.com/conventional-battery-7720.html
Is there a preferred replacement battery, or should I get another one of these?
Thanks!
Tim Miller
Re: Does this battery work? 65 CA77
Post by Tim Miller » Thu Jun 15, 2017 4:05 pm
I have had good luck with the sealed Motobatt MB9U. There available on eBay.
Tim
jstark wrote:Hi there,
Thanks!
brewsky
Post by brewsky » Sat Jun 17, 2017 4:33 am
Thanks!
12n9-3a has the correct left hand negative and I just installed one of these:
https://www.amazon.com/WPS-Conventional ... B003CJQMF8
for $30 shipped.
The "early" dreams took a different size battery, so you may want to double check the battery box dimensions just to be sure. Also, mine does not have the tool tray, so I'm not sure about the correct height dimension for one that does. (The 12n9-3a is 5-1/4" L x 3" D x 5 1/2" H)
The motobat Tim recommended is reversible so terminal orientation is not an issue.
jstark
Post by jstark » Mon Jun 19, 2017 6:20 pm
I have found out that my bike is actually a 64, does that make any difference?
Hoosier Tom
Post by Hoosier Tom » Mon Jun 19, 2017 8:05 pm
jstark wrote:I have found out that my bike is actually a 64, does that make any difference?
Yours would take the early battery. Here is an old post that talks about the battery on the 2nd page.
http://www.honda305.com/forums/vin-help-t7633987-7.html
Here is a post on an alternate battery.
http://www.honda305.com/forums/agm-batt ... t7936.html
HT
