Just like to say thanks for the information I gleaned from these pages. I was able to use this to replace my sealed beam unit with a standard replaceable lamp reflector with side light from a CB400F, at a much reduced price and no longer tied to the sealed beam. It also gives a much easier option for the future to install a LED.
Same diameter and looks of the original unit, only work needed to reduce the depth of the lamp connections as the speedo cable restricts the standard connection.
Cheers
CL77 headlight conversion from sealed beam
- barnbiketom
I used a Yamaha xs400..They are 6 3/8" too but I needed to bend the 35/35w h4 terminals flat to avoid the speedo cable, then used Spade connectors.
I wanted to do a led but even the ones with remote inline power supply are too high to clear the speedo cable... Because it has a fan on there...
You would think there's an LED short enough but I haven't found one yet!!!
How about this? http://www.ebay.com/itm/80W-H4-Motorcyc ... 3a97dee35f
- barnbiketom
