Which black wire goes to the 6 cavity connector?
catterar
Post by catterar » Wed Sep 12, 2012 9:30 pm
When I removed the headlight from the '64 Dream I bought on eBay this is how I found the ignition switch.
Ignition Switch Back by catterar, on Flickr
Which black wire goes to the 6 cavity connector and where does the black wire with the stripe next to the green wire at the bottom of the picture go?
Thanks for any help.
Bob
brewsky
Post by brewsky » Thu Sep 13, 2012 7:06 am
Here's the wiring diagram and switch info:
http://www.honda305.com/forums/dreams-c ... t6088.html
catterar
Still Confused
Post by catterar » Thu Sep 13, 2012 6:29 pm
Thanks, I'd looked at those diagrams, but still can't tell which black wire goes to the connector and which goes to the neutral light. Does it make a difference? Both wire connections on the switch are labeled IG.
Bob
rzgkane
Re: Still Confused
Post by rzgkane » Fri Sep 14, 2012 10:17 am
catterar wrote:Thanks, I'd looked at those diagrams, but still can't tell which black wire goes to the connector and which goes to the neutral light. Does it make a difference? Both wire connections on the switch are labeled IG.
Bob
Get out a multimeter and do a simple continuity check on the actual wires. Pretty easy.
1965 CA77Dream
catterar
Darn why didn't I think of that
Post by catterar » Fri Sep 14, 2012 11:46 am
How come the simplest solutions are so easy to overlook. I guess I like to complicate things.
Thanks,
Bob
rzgkane
Re: Darn why didn't I think of that
Post by rzgkane » Fri Sep 14, 2012 11:56 am
catterar wrote:How come the simplest solutions are so easy to overlook. I guess I like to complicate things.
Thanks,
Bob
Human nature, my friend! I do it all the time. The bullet connector for the neutral switch is in the cavity behind the carb. Green with a yellow stripe (or vice versa) if memory serves me.
1965 CA77Dream
