CA78 Front end grounding?
rzgkane
Post by rzgkane » Wed May 23, 2012 4:39 pm
Actually, my Dream has the dual connector for both the blue and green so it might be that easy. It's running so good lately (knock on wood), though, that I'm reluctant to touch it!
OldStan wrote:
Strange, huh? But correct. Seems like a swap of the blue and green wires on my CA78 Dream would reverse that.
I actually thought about that, but since the blue wire has the dual connector for the high beam indicator light it wouldn't be quite that simple- beside, Honda knows best, right?
OldStan
Post by OldStan » Wed May 23, 2012 4:45 pm
I just realized that mine has dual connectors on both too. I wasn't thinking about the colors you stated. It would have to be the blue and red wires that are swapped. The green is the hot wire to the switch, the dual being for the speedo "dash" light.
63 CA78
rzgkane
Post by rzgkane » Wed May 23, 2012 5:04 pm
Ahh yes. You are right. Swap the blue and red. Green is hot from ign to speedo light and dimmer sw.
OldStan wrote:I just realized that mine has dual connectors on both too. I wasn't thinking about the colors you stated. It would have to be the blue and red wires that are swapped. The green is the hot wire to the switch, the dual being for the speedo "dash" light.
