How to run a CB77 without a battery?
1204_cb77
Post by 1204_cb77 » Wed Mar 06, 2019 2:02 pm
davomoto wrote:I've done it with a computer grade capacitor, but haven't managed to get a working headlight yet. The excess power from the stator needs to go somewhere, so the "battery eliminator" fills that need.
Davo
Hey mate, do you have any info on how you wired up your capacitor? I am doing a battery delete and just going to run kick start. Im turning the build into a flat track. Thanks for any info you could lend!
Cheers.
mike in idaho
Post by mike in idaho » Wed Mar 06, 2019 7:53 pm
The plus and minus terminals are connected to the original battery terminal wire ends, that's all there is to it. Best way to do it is to ditch the original rectifier and replace it with a modern single phase regulator/rectifier, that will take care of the excess voltage.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
1204_cb77
Post by 1204_cb77 » Wed Mar 06, 2019 8:11 pm
mike in idaho wrote:The plus and minus terminals are connected to the original battery terminal wire ends, that's all there is to it. Best way to do it is to ditch the original rectifier and replace it with a modern single phase regulator/rectifier, that will take care of the excess voltage.
Thanks Mike for the info. The only wiring I received with the bike was the minimal wiring coming off the ignition coils and points area along with the short leads coming off the stator. No biggie, just starting from scratch pretty much. The wiring on the bike now is pretty shot. Thanks again.
mike in idaho
Post by mike in idaho » Thu Mar 07, 2019 10:18 am
They have two harnesses originally, an ignition harness(which you apparently have) and a main harness for the lights & horn. If you have the original key switch you can attach the rectifier output and the capacitor positive lead right to the hot terminal of that switch.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
1204_cb77
Post by 1204_cb77 » Thu Mar 07, 2019 12:50 pm
mike in idaho wrote:They have two harnesses originally, an ignition harness(which you apparently have) and a main harness for the lights & horn. If you have the original key switch you can attach the rectifier output and the capacitor positive lead right to the hot terminal of that switch.
OK very cool, I do have another harness in the box of parts but no key. I could always order up a new switch set and wire it in. Thanks man
mike in idaho
Post by mike in idaho » Thu Mar 07, 2019 3:22 pm
If you take that old switch to a locksmith and show him the number on it he may be able to make you a new one.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
1204_cb77
Post by 1204_cb77 » Sun Mar 24, 2019 10:40 pm
mike in idaho wrote:If you take that old switch to a locksmith and show him the number on it he may be able to make you a new one.
Ok so another question now :) Is it possible to go keyless? I need this thing "bare bones" think of XR80 style wiring bare bones..Kickstart only with a kill switch easy. I literally just need it to run haha. Any tips would be grand! Thanks again all. Slowly going back together. Waiting on motor parts and frame is coming back from paint this week!
I have coils, two condensers the points setup, etc.. and a butchered up rats nest harness that I really don't want to use. The only thing keeping me stumped is what to do with the wiring from the stator..Being that there will be no lights at all I mainly just need to wire up my ignition system.
Cheers
